Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #21
Old 07-16-2015, 08:11 PM
Scott Hersha Scott Hersha is offline
For the GPS 20A - is it compatible with original G3X (not touch) system coupled with GTX 23ES transponder?
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 07-16-2015, 09:47 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Originally Posted by Jim Ellis View Post
What is the version number for the GTN 750 software that I should have installed for this functionality? Finding an authorized Garmin Dealer that even knows what I am talking about has been very difficult.
Pacific Coast Avionics says the new GTN software is supposed to be released in the 3rd Qtr.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 07-16-2015, 09:49 PM
haydnc haydnc is offline
New GPS 20A Provides Cost-Effective Path For Meeting 2020 ADS-B Requirements In EAB/LSA
Does this meet a TSO as well? TSO146?
Joining the popular GMC 305 in our lineup, the new GMC 307 autopilot control panel gives pilots additional features most-requested by customers.
Arrgggghhh! Same as last time! the Day I installed another brand auto pilot (which has not worked since day 1) Garmin release their autopilot! Today, I have just been advised that my GMC305 has arrived! Arrggghhh!
Haydn C
Newcastle, Australia
Old 07-16-2015, 10:55 PM
marcusadolfsson marcusadolfsson is offline
Great news!
For a G3X Touch system with GTX 23ES, do you need serial + can bus connection? Or can you just run the serial?
E-LSA Carbon Cub N80DB
Eclipse 500 N55TJ
Old 07-17-2015, 05:30 AM
catmandu's Avatar
catmandu catmandu is offline
Originally Posted by dweyant View Post
Any show specials?
1/2 off a GTN 650
-Dan
+1! I've got cash!
Mike C.
Sierra Nevada
RV-6A bought flying
Old 07-17-2015, 06:10 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by marcusadolfsson View Post
Great news!
Hello Marcus,
Technically, you only need to add power, ground, antenna, and the single ADS-B+ RS-232 connection to the GTX 23ES to become ADS-B Out compliant with the GPS 20A/GTX 23ES.
As shown in the picture above, the GPS 20A has two status LEDs on the box, one for power/communication, and one for GPS status. When you first power up the box you will see a slow flashing green LED next to the antenna connector. The flashing green LED tells you that the GPS 20A is acquiring the WAAS GPS signal. As soon as it gets a full 3D Differential fix, the light turns to a steady green and you know you have a great installations and ADS-B+ data is being transmitted.
In the transponder window on your G3X Touch display, the yellow "NO ADSB" annunciation at the top of that window will go away as soon as the GTX 23ES sees that it is receiving ADS-B+ data from the GPS 20A, so you never have to worry about seeing the status LED on the GPS 20A after initial installation. Make sure and set the "Position Integrity" on your GTX 23ES transponder configuration page to "IFR GPS 1E-7" as this tells the system that it will no longer be using the GPS built into your display for ADS-B Out.
We sure hope you also connect the CAN bus at some point because not only does the GPS 20A provide an additional "IFR quality", high integrity WAAS position source to your G3X Touch system, but the ADAHRS unit(s) sitting on the CAN bus will also recognize that this high quality data is present and they will automatically prefer it and use it for aiding the AHRS solution. The ADS-B+ data sent directly to the transponder from the GPS 20A is just a subset of the complete data set that is being provided to every component in your G3X Touch system over the CAN bus.
When we review the high resolution 3 axis GPS velocity data provided by the GPS 20A that we collect in our flight testing, we sure like what we see!
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-21-2015, 03:13 AM
Richard Connell Richard Connell is offline
Great addition guys.
Now how about some decent maps outside the USA? The G3X is pretty useless in that regard.
Other vendors now have geo-ref WAC/ERC/TAC/IFR / Plates etc available outside the USA except Garmin - and at an affordable price point.
That would be a nice evolution.
Richard
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 07-21-2015, 02:27 PM
KRviator's Avatar
KRviator KRviator is offline
A comment I saw on PPrune suggested the GPS20A is not TSO'd, it only "meets the performance requirements of the TSO", which is fine for the U.S., the FAA recently clarified that's all that has to happen, but for Australia and Europe as well, AIUI, we must have a device that has actually been certified against the relevant TSO, which rules out the Garmin GPS20A as well as Dynon's new GPS-2020.
The best I can see for stand-alone position source is the FreeFlight 1201 at a cost of nearly $3000USD. Ouch. Thank you very much CAsA...
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 07-21-2015, 02:29 PM
rapid_ascent rapid_ascent is offline
Well I hope the new GMC-307 mounting scheme is much better. What a pain this was with the GMC-305, at least for a standard radio stack mounting. For me it would be worth buying the new model for this reason alone.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 07-21-2015, 02:37 PM
dweyant dweyant is offline
Any word of a discount on the GTN650 like garmin usually does?
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
