Old 07-12-2015, 05:22 PM
TomVal's Avatar
TomVal TomVal is offline
Default GRT SX Loading Waypoints Problem...
I have a GRT SX-200/100 dual screen display with the current unit and navigation software installed. Today I went to load a flight plan to Triple Tree Airport (SC00). In typing the airport identifier into the flight plan, the numerals 0, 1, & 2 were not available in the selectable "numbers column" from the "Add" waypoint page although numerals 3 thru 9 were. So basically, any waypoint that has the numerals 0 thru 2 in it presently cannot be built. Has anyone else have had this problem?
Also, the system will not allow me to add a user-defined waypoint into an existing flight plan, however the system will allow me to go present position direct to a user-defined waypoint.
I would appreciate any input on this. I've also sent an inquiry to GRT.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 07-13-2015, 06:16 AM
h&jeuropa h&jeuropa is offline
Tom,
Not sure it will help, but there are a couple tutorials on waypoints on the GRT website under Support, Feature of the Week.
Jim Butcher
Old 07-13-2015, 06:20 AM
Capflyer's Avatar
Capflyer Capflyer is offline
Hmmm, I never expereienced that with my SX. I know that user defined waypoints are entered using no spaces, not sure if that is an issue here. Always had access to all the numbers. Is there any way you may have transposed 0 for O either in the airport ID or the entry?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 07-13-2015, 01:45 PM
TomVal's Avatar
Just got off the phone with Jeff at GRT. I will try a reload of the display unit software. He has received no other calls regarding this problem. I'll report back in a few days with the results.
Tom Valenzia
RV8 (Sold)
Old 07-17-2015, 12:43 PM
TomVal's Avatar
I reloaded the unit display software and now my missing numerals are displayed, however, the system still will not allow me to add a user-defined waypoint into an existing flight plan, although it will allow me to go present position direct to a user-defined waypoint.
Jeff at GRT is going to run some tests with his software and get back to me.
Tom Valenzia
RV8 (Sold)
Old 07-30-2015, 01:27 PM
TomVal's Avatar
Default Problem Solved...Mea Culpa!
I did not realize that a user defined waypoint name cannot share the name of any waypoint already in the national database. For example, I named a user defined waypoint as "WALLY". When I attempted to load WALLY into an active flight plan, the LIST function showed that there were two waypoints in the national database to select from. My user defined waypoint "WALLY" was not listed as a choice, however, within the user defined waypoint page, the system would allow me to go P-P direct to my user defined "WALLY". After renaming WALLY I was able to load the waypoint into a flight plan.
Probably haven't explained this very well, but the bottom line is that I failed to RTFM.
Tom Valenzia
RV8 (Sold)
