Old 07-11-2015, 04:47 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default Want to borrow a Garmin autopilot servo in Savannah
We're well along in the installation of a second G3X touch screen and autopilot, but the interesting phenomenon is that the system doesn't see the pitch servo and has errors talking to the roll servo. The CAN bus is okay, voltage and ground are okay at the pitch servo, CWS is disabled on the configuration page and the wire to the pitch servo is not grounded. When the pitch servo is unplugged and replaced by the appropriate plug, everything works. Hypothesis: the pitch servo is bad.
Plan A, and it's really ugly, is to physically swap the two servos and see if the problem follows the servo.
Plan B, in case anybody needs an excuse to fly to Savannah, is to plug in a different Garmin servo (not connect it to the elevator linkage and not install it, just plug it in electrically) and see if the rest of the system works with that servo.
And of course, we're trying to get this done for a mid-week departure to Oshkosh.
Anybody want to fly to Savannah?
thanks
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 07-11-2015, 05:03 PM
Brantel's Avatar
Brantel Brantel is offline
I know that many times it is easy to suspect the device is DOA out of the box, I have had many discussions with TeamX on how detailed the testing procedures are at Garmin before a device ships that this kind of thing is almost unheard of.
I would triple check the wiring...
  • Ensure that the CANBus lines are not flipped.
  • Ensure that the termination advice is followed and that you did not accidentally leave one end unterminated and/or make sure that 3 terminations or more were not accidentally installed.
  • Ensure that any stubs off of the main trunk of the CANbus follow the requirements of the latest install manual.
Also ensure that you are communicating with TeamX as they are awesome!
Good luck!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-11-2015, 05:26 PM
Been doing all that, thanks.
Was pondering flipped CAN bus lines as a possibility
Found two terminator plugs in the CAN bus that we didn't know about. The bus worked fine with the extra plugs in, aside from the servo issue.
And TeamX is four steps beyond impressive.
Ed
Old 07-11-2015, 06:40 PM
There's a jumper on the pitch servo that's not on the roll servo and I bet that's our error. Well try that tomorrow.
If you hear whoops you'll know the source.
Ed
Old 07-11-2015, 06:49 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
I think you have to calibrate the heading reference too before the servos will engage. Just throwing it out there.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 07-11-2015, 06:55 PM
We're adding a second screen and autopilot, so lots of that should have been done already. Thanks though.
