Old 07-08-2015, 06:55 AM
pvalovich pvalovich is offline
Default Electric Flap Circuit
Electric flaps suddenly stopped working - but motor works ok with external voltage supply attached. -8A with three position center neutral switch. Anyone have the wiring diagram for this circuit? Don't have access to my build documents.
Old 07-08-2015, 07:22 AM
rleffler's Avatar
rleffler rleffler is offline
Unfortunately, only the builder can answer that question. No two builds are identical, especially with the electrical designed.
The good news is that flaps aren't too hard to troubleshoot.
  1. Check the breaker or fuse
  2. Do you have voltage at the flap motor when the switch is in the up or down position?
  3. Do you have voltage at the fuse or breaker?
  4. Test the power feeds (with the power off) to test for a short to ground. Something chaffed or cut through the insulation
  5. Trace the wires looking for an open circuit
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-08-2015, 08:30 AM
Raymo's Avatar
Raymo Raymo is offline
Are you using a relay between the switch and motor? (should be)
If not, depending on your switch wiring, you may have exceeded the wire's capability to handle the load, which would melt said wire.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 07-08-2015, 10:19 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
If there is a "standard" wiring method, this is it -
From Aerolectric Bob...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-08-2015, 01:00 PM
n82rb's Avatar
n82rb n82rb is offline
i'm willing to bet 80% are wired just as gil posted. mine included.
bob burns
RV-4 N82RB
