Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
  #21
Old 01-18-2018, 05:04 AM
FORANE's Avatar
FORANE FORANE is online now
Originally Posted by g3xpert View Post
Hello Forane,
Perhaps I didn't make this clear, but the GTX 45R/345R/345 ADS-B In/Out transponders provide the ?Traffic: 10 O?Clock, High or Low or Same Altitude, 2 miles.? type aural traffic alert regardless of what display is being used. In other words, a G3X system is not required to hear these alerts for the GTX 345/345R.
And yes, the GDL 88 also provides this type of traffic aural alert.
Steve
Thanks for your clarification Steve. So that means for 2020 compliant ads-b out, with audio traffic alerting, without sacrificing anonymity in 1200, the gdl88 is garmins only option, correct? Assuming a device such as a GTS 800 is not included.
I had heard one pirep of the gdl88 where the pilot stated he didn't receive these alerts often. Does the gdl88 have set up parameters of alert areas I.e. only alert within certain altitude and range? Or does that have to be setup within a connected device such as the 430W or 496 I have in the plane?
Please advise
Steve
Lancair 235/340
RV-9A (2013 - 2016)
Old 01-18-2018, 08:02 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Please advise
Steve
Well, my name is Steve also so I will offer this: There is the gdl82 for ADS-B OUT UAT that has anonymity. Of course it has no ADS-B IN so you would have to combine it with the GDL-39 or GDL-52 to get IN capabilities and provide your aural alerts.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 01-18-2018, 08:20 AM
FORANE's Avatar
Hey Steve
Do the gdl39 and or gdl52 send aural alerts directly to the audio panel or through an efis or tablet etc? Can those alerts be setup for proximity within the gdl?
Lancair 235/340
RV-9A (2013 - 2016)
Old 01-18-2018, 10:15 AM
RVbySDI's Avatar
Hey Steve
All aural alerts come from whichever display unit one would use to display the traffic. That would be EFIS displays of whatever manufacturer you choose to use, GPS displays of whatever manufacturer you choose to use, moving map displays of whatever APP manufacturer you choose to use that is running on whatever tablet from whatever manufacturer you choose to use.
In my case I have a Garmin GDL-39 sending ADSB-IN information to two distinctly different instruments, a Garmin GDU470 and an Ipad running Foreflight. Those two units are in turn sending individual and separate audio signals through hard wiring to a Garmin GMA245 audio panel.
There are no audio connections directly from the GDL-39 to the GMA245 audio panel. The GDL-39, or any other ADS-B IN unit, is only providing specific DATA, in a specific standardized format, to the various other instruments that either display that data visually, or aurally, or both.
RVBYSDI
Steve
RV9A
https://rvwings.com
Old 01-18-2018, 12:15 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
In case a picture helps to explain this.
GDL 39R
GDL 52R
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
