Old 07-07-2015, 11:55 AM
Aviator22S Aviator22S is offline
Default AFS Control Module and Infinity Sticks
Has anyone ever installed the Infinity stick grips with the AFS Control module? I have only had experience with Vertical Power in the past and have never had a problem with that system, but with the AFS CM it seems there are not enough pins in the Control Stick serial port for all the functions of an Infinity Stick. I'm sure I'm not the first one to encounter this, but I'm also hoping that I'm not attempting to do the impossible by integrating this stick into the rather simple AFS Control Module. Any tips?
Old 07-07-2015, 01:25 PM
ArlingtonRV ArlingtonRV is offline
Not a direct answer to your question, but you might as well disregard the AFS Control Module unless you want one of their pre-made panels. I already asked and they won't sell just the Control Module.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 07-07-2015, 02:08 PM
Raymo's Avatar
Raymo Raymo is offline
Not sure this helps but I'm installing Infinity grips and using the following relay board (3 axis) for trim and flap control.
http://compositedesigninc.com/Trim_Relay.htm
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 07-07-2015, 07:51 PM
SMRacer SMRacer is offline
Default Infinity
There is no reason that ALL you stick functions have to go through the control module.
In fact you may want some of them wired directly to user functions.
Jim
AFS panel upgrade in progress
N37PK
