GoPro
Doug,
Depending on lighting conditions and haze I use an ND .8 filter or a circular polarizer. I run the GoPros at 1080 with 60fps.
One camera on my head- run medium or narrow FOV. Wide makes everyone look far away even when you are flying close fingertip position.
The other camera on the back deck behind rear seat facing forward with wide FOV & same 1080/60fps.
Make sure to do the latest update to the camera, get high speed class 10 Micro SD cards and only use WIFI to "sight in the camera" to check the preview. Start the recording manually and shut it off manually. Every time I have used WIFI it shuts off on it's own then shuts the camera off. Evidently the dynamic flying environment with radio transmission, transponder squawks, radar hits etc, the WIFI can't handle it.
I'm not a whiz bang avionics guy so I don't really know what's happening with the WIFI. Would really like to use it in flight but not having much luck so far. Anyone out there know how to fix this?
Oly
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
