07-05-2015, 05:33 AM
Aft CG..live and learn
My stepson and his girlfriend wanted to see the local area yesterday, so I obliged, since she's a new girlfriend
She climbed in the rear and I leaned the seat back so Aaron could get in but he said, "Pierre I'm sitting in the back so we can take pictures of ourselves."
I told him that I'm afraid we may well have a too far aft CG, then I realized I had about 50 gallons of fuel that's mostly forward of the CG, so we went. Later calculations showed us as 2" forward of the aft limit...good to know but it might have been dicey if we'd flown long enough to burn most of the fuel...I'll calculate that situation as well. With 1 hour of fuel remaining (15 gals.), we still would be within CG by 1 inch, no baggage.
Bear in mind that Aaron is 6'4" and their combined weight around 370#.
With some extra down trim added for good measure, we took off and the airplane flew remarkably solid, no oscillations and was rather fast. Amazing airplane.
Live and learn.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
07-05-2015, 06:11 AM
How any people have calculated their ZFW CG before a flight, when you takeoff with the CG towards the aft limit anyway?
I suspect the answer would be "not many"... But it was mandatory for us on the C130's as part of our W&B calculations, just in case.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
07-05-2015, 07:05 AM
Use W&B spreadsheet for longer trips
I built a W&B excel spreadsheet that calculates arrival fuel CG for each flight because on my -7 with 2 up and baggage it can get to aft of the aft CG with low fuel. The CG cells actually turn red when an out of range CG is detected.
Not normally an issue when 1 up going anywhere or 2 up with limited baggage gear for local fly-ins. It is an issue when travelling 2 up going on longer trips (such as Oshkosh to HBC). I use it mostly to manage baggage and plan fuel legs.
07-05-2015, 07:07 AM
Fltplan has a nice app for android and iOS that I use. Once it is configured for your airplane you just punch the numbers in and the flight time. It will show CG at take off, landing, and at 0 fuel. I use it all the time if loading an unknown load. It's pretty hard to load my 10 aft cg. I am at the far forward limit when solo.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" -   +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
07-05-2015, 07:25 AM
Super Moderator
AFS on screen
The AFS screens have a visual W&B calculator right there in front of you, giving you a visual indication of TO CG and CG at the planned fuel burn landing. No excuse for not using it before every flight.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
07-05-2015, 08:39 PM
Vic
I also have an AFS and find this function very informative. Still haven't flown with a passenger in back yet but before I do I will certainly use this function to ensure I am within the limits on takeoff as well as landing.
Thanks for the thread Pierre. Serves as a good reminder. Glad you were within specs.
So how'd she handle compared to your normal load out?
Charlie
RV-8
07-06-2015, 04:54 AM
Vic
Unfortunately, I have the dinosaur D100, Vic. Gotta do it with calculator and pencil. I had done gross weight CG and forward CG calcs before, so I had a fair idea of what differing loads would do. We all need to practice CG calcs more often anyway.
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
07-06-2015, 09:59 AM
ForeFlight has a W&B page
ForeFlight has a weight and balance calculator also. Pretty easy to set up and use. It is under the "More" tab at the bottom, then select Weight and Balance from the list. Gives a graphical depiction of where you are in the envelope at Takeoff, landing and zero fuel.
07-06-2015, 01:21 PM
"ForeFlight has a weight and balance calculator" ... if you purchased the Pro option.
I use the Aviation W&B iPhone/iPad app for a $10 one time fee rather than the annual FF fee.
Also have a spreadsheet to do more detailed calculations on my PC.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
07-06-2015, 01:57 PM
We just did a trip to Johnson Creek in the 10 and weighed everything going in. Did the weights on the AFS and we were .2 forward of aft CG at empty tanks. We had the two kids and the dog in the back. Plane flew just fine. The full to empty weight on the tanks do not change the numbers very much. It is the luggage in the back that really pushes it aft. I also find the full aft luggage makes the pedals a bit more sensitive holding the line in gusty conditions on the ground.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
