Have you tried the simulator mode?
START UP During start up the GX60 will complete an IFR output test if the unit is installed for IFR. A host of other internal checks are completed at the same time. This is a FAA requirement for IFR certification. It takes the unit a minute or so to go through the complete procedure but you can press the "skip" key and by-pass all of this. During the start up mode you can select the "Simulator" mode.
Press the NAV key when you turn the power on...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
