Old 07-01-2015, 01:40 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default WW-151 Spinner Bulkhead shift
With about 470 hours on our RV-3, we've probably got one of the higher time Whirlwind 151 props out there. this three-blade prop comes with a pre-fit spinner and has been simply outstanding on the airplane. We've had no issues with the prop at all, and just now noticed a little spinner problem I want to share.
Several people noticed a slight wobble in the spinner when we have taxied in - it is not felt or seen in the cockpit. What I noticed the other day was that the spinner seemed to be rubbing on the cowling (we have a pretty small gap) down about the 4:30 position (viewed from the font). My first thought was that it was time to get out the engine mount shims - and then I put my hand on the spinner, and it shifted!
Long story short - the rear spinner bulkhead is composite, and the bolts had, over time, squeezed the material enough that they were no longer tight. This elongated a hole or two just a little bit. I removed all of the safety wire and took about a half turn on each bolt to get them tight again, then re-safetied. If it moves again, we'll pull the bulkhead and reglass the holes.
Something to check if you are running a composite rear spinner bulkhead!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
