Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 06-30-2015, 12:39 PM
tmbg's Avatar
tmbg tmbg is offline
Default confused about my prop
Hi folks,
I have an RV6 that I bought to fly while I finish up my 7, and it's got an O-320-nothing 150hp engine with a sterba 68x72 wood prop.
I turn 2500rpm static at 2000' DA, I can easily run over redline in cruise, and max cruise at 8000' DA at 2700rpm is around 146KIAS.
I've seen other posts on here where people said they have 150hp O320s with similar props and they turn far less static. I even saw someone with the same sterba 68x72 on a 150hp, and turned 2250rpm.
The only conclusion I can come to is that either my engine is producing considerably more than rated power, or my prop isn't the marked pitch.
I'm trying to figure out what sort of prop I should be looking for to make this airplane faster, and also it's tail heavy; I can't get it in aerobatic limits as is, and a metal prop or even a CS prop would go a long way toward helping the CG.
Ian
Old 06-30-2015, 01:15 PM
Mel's Avatar
Mel Mel is online now
There's another thing you haven't mentioned. Have you checked you tach? If it is a mechanical analog tach, those things are notorious for being inaccurate.
It's not at all unusual for them to be 200 rpm off.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-30-2015, 01:31 PM
tmbg's Avatar
yeah, that's been on my mind as well. I have a friend bringing an optical tach out tonight so I can rule that possibility out!
Ian
Old 06-30-2015, 03:01 PM
jrs14855 jrs14855 is offline
Default Prop
Perhaps someone has done some carving on the prop and it is no longer the stated pitch.
Old 06-30-2015, 03:13 PM
tmbg's Avatar
Perhaps. Does anyone have a procedure for measuring/estimating the pitch of a prop?
Ian
Old 06-30-2015, 03:53 PM
Infidel's Avatar
Infidel Infidel is offline
I have the same prop on my -4 with a 0320/160. 2500 rpm on take off and I think my numbers are pretty much the same as yours. IMO, this setup is a good and smooth climber but lacking for more speed in cruise.
Old 06-30-2015, 04:50 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
146 KIAS at 8000' DA equates to about 190mph, which is consistent with Van's performance spec for a 150HP RV-4.
I had a similar set-up on my RV-4 with a Pacesetter 200 which would easily overspeed at low altitude. I now have a Catto that is pitched much coarser but won't overspeed at low altitude and has a comfortable WOT cruise RPM at high altitude, but the trade-off is a lower static and climb RPM with resulting reduced performance in those phases.
A FP prop will always be a compromise, so it's mainly a matter of finding the sweet spot for your kind of flying. A metal prop is more efficient, but the Sensenich will be subject to a 2600 RPM limit. Their ground adjustable would allow you to play around and find your best compromise, but they don't come cheap.
a 72" pitch from one manufacturer won't neccesarily equate to a 72" pitch from someone else. Nominally it's the Tan of the blade angle at the tip multiplied by the circumference (2*PI*D), but there seems to be some variation in practical measurement and the airfoil section can influence the effective pitch relative to nominal.
Old 06-30-2015, 06:44 PM
gasman gasman is offline
You really need a manifold pressure gauge to know if you are loading the motor.
RPM alone is just not enough to let you know what is going on.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 07-02-2015, 09:03 AM
tmbg's Avatar
I put an optical tach on it last night, and confirmed that my tach is correct. Optical tach showed 2520rpm static, mechanical was right at 2500
Ian
Old 07-02-2015, 09:24 AM
flyboy1963's Avatar
Default length?
have you actually measured the length?
most common mod to a prop is to shorten it.
a previous owner may have chopped off 2" because it wasn't revving enough on a different engine?...or...heaven forbid, someone took a chunk out of the end when they hit something, and this was the 'repair'.
perhaps Mr. Sterba could shed some light on this? or for $600, try a different pitch?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
