Old 11-17-2006, 07:28 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default lube for brass npt brake fittings
Can someone point me to a source that indicates what (if any) lube should be used on the threads of the brass fittings that go into the master cylinders? I looked through 43.13 and millions of brake posts on this forum to no avail. Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 11-17-2006, 07:44 PM
I can't point you to anything specific. I used BakerSeal.
this was my guide.
http://rvproject.com/20050420.html
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-17-2006, 08:49 PM
AndrewTR30 AndrewTR30 is offline
Default What Matco said.
They recommended using some type of lube on the threads. I asked about using Fuel-Lube and they said "yup, that'll work."
Andrew Rayhill
RV-10 40078
Phoenix
Old 11-17-2006, 11:21 PM
G-force's Avatar
G-force G-force is offline
All npt fittings should have a thread sealent on them. Fuel lube, baker seal, PST, esy turn...as long as it is compatable with the fluid your sealing, it will work.
Mike Sumner
Castaic, Ca
Old 11-18-2006, 05:54 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I use a teflon sealant made by LockTite. It is a white cream. I think it is # 567?
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 11-18-2006, 09:08 AM
G-force's Avatar
Roberta
That would be Locktites high temp PST with teflon. Thats my prefered thread sealent, I use a lot of it at work.
Mike Sumner
Castaic, Ca
Old 11-20-2006, 09:43 AM
trib trib is offline
Question Locktite 567 good for fuel line fittings too
Would the locktite PST 567 be good for use on the fuel line AN fitting threads also?
Old 11-20-2006, 01:24 PM
G-force's Avatar
on the 37 degree side? It would work fine as an anti sieze, we have to use it on every one of the thousands of stainless fastener we use at work to prevent galling. I believe normaly the 37deg an side is done dry, although I have heard of some people use some sort of antiseize. It wont do anything for sealing, that is acomplished on the mating 37 deg surfaces.
Mike Sumner
Castaic, Ca
Old 11-20-2006, 02:22 PM
hecilopter's Avatar
hecilopter hecilopter is offline
Default I tried everything
fuel lube, teflon, Baker seal and the brake fittings still leaked! I eventually removed them all, applied Baker seal, and tightened the fittings until I thought they would break off. That fixed it! For me, no matter what I used, I simply wasn't tightening the fittings enough. Surprisingly, I got an extra turn or 2 from what I thought was originally tight. Be sure and tighten these things until you think you can't turn any further.
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
Old 11-20-2006, 03:48 PM
My worry when I did this was I had to get them a FULL turn and it felts like quite a gamble. What if I started and I only got it to the 5 o'clock position? I elected to stop where I was and see what happens.
Bob Collins
St. Paul, MN.
