I did that twice....
I did that twice with a tungsten bar. Both were too big to massage, one had some cracking. Both times I drilled it to a 1/2" hole and made a four rivet well radiused and edged square patch over the hole, minding the edge distances, with 4 426-3's out of the same thickness as the parent. Once was fuse bottom, once similar to yours. Fifteen minute diversion, move on. Even I have to go looking for them now that it's painted. Aggravating when it happened....hardest part was dimpling the parent metal in place. Good luck, ymmv.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
