06-29-2015, 04:35 PM
For those looking for a great deal from Garmin, have they ever presented a product that was less expensive then their competition?
Just sayin'
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
06-29-2015, 04:50 PM
You know, I don't get worked up about too many issues but this is one that will definitely have me writing and calling my Congressman. I find it completely unacceptable that the FAA would deny critical traffic information to users that don't have a certified system. My engineering training tells me there should be ways to implement a quality or certainty factor for the inputs to the system that would allow controllers to understand the degree of confidence in any aircraft reporting on the system. That is no different from the current architecture where a non-squawker is only seen on raw radar. The controller might not see a raw target at all but, if he does, the observation provides valuable information. At a very minimum, we should categorize non-compliant ADS-B subscribers as 'raw' data and allow them participate. Denying non-compliant users access to the best information is not just wrong, I think it would be criminal. The first mid-air where the FAA refused that valuable information to a capable subscriber will be a landmark case.
For goodness sake FAA, apply the reasonableness rule to this one!
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
06-29-2015, 10:04 PM
I put in a Freeflight system that provides ADS-B Out and, through my iPad, ADS-B In. As I understand it experimental must demonstrate performance equal to the TSO. I use the same system STC'd in my Cherokee. I think I'm covered.
Let me say this about ADS-B: it is a wonderful tool for avoiding traffic conflicts. Through my use I have concluded that I can't reliably spot traffic until it is within 2 miles. After two years I have come to regard ADS-B as a valuable friend in the cockpit.
07-20-2015, 08:56 AM
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
V AF donation through June 2021.
07-20-2015, 09:10 AM
Originally Posted by DHeal
Oh thank God (Or rather Dynon/AFS)! This is exactly what I need.
And just 2 days ago I trimmed the wires and installed the GPS puck. oh well, out it comes.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
07-20-2015, 10:26 AM
Great marketers too...
Got to love the model number they came up with ....SV-GPS-2020...finally product numbering that makes sense!
07-20-2015, 02:20 PM
Why take it out? Instal the 2020 unit as primary and connect the old one as a backup GPS.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
07-20-2015, 02:23 PM
Because I won't have anything to connect it too.
Jeff Caplins
California
RV7 N76CX
07-20-2015, 03:53 PM
From the Dynon FAQ site:
"I already have a SkyView/AF-5000 system. Do I have to tear apart my aircraft?
No: It couldn?t be easier to retrofit. If you are already using the SV-GPS-250 as your position source, it?s truly a drop-in plug-and-play replacement. The SV-GPS-2020 uses the same four wires and has the same mounting pattern. If you have an unused serial port on your system, you can opt to add the SV-GPS-2020 without removing your existing SV-GPS-250. This gains you a second GPS position source for redundancy/backup."
07-20-2015, 04:26 PM
That's what I was thinking...but for the RV12 owners, the question will be where does it need to be mounted to make the signal all legal like...I sure don't want to be staring at it outside the front window....maybe a custom wider or longer GPS antenna tray in the engine compartment?
Or just take the old one out and sell it here?
