Brass tube
Originally Posted by bill v
I have trouble when I have to drill a #19 or 3/16 hole using the hole in the front as a guide the front material is too thin to hold the drill. I made a tube to use as a guide and drill a 1/16 hole in the center of were I want the bigger hole seems to be the best way I have found. took a 3/16 rod drilled a 1/16 hole through it the long way (lathe) then turned the one end down to a #19 and cut it off at 1 inch. you put the tube in the hole in the front skin then drill through the center of the tube with a 1/16 drill then work the hole up to the correct size for me I go 1/16 then a 40 then 30 then 21 then ream #19. if I have a 3/16 hole I use the other end of the tube. also I have a .064 piece of scrap with a 3/16 hole in it around the tube to help keep the tube perpendicular
I don't have a lathe so...
I use three sections of brass tube. Smallest is perfect for #41 bit. Slide it into the next size up and slide that one into the next size up. Lube with some Boelube. Perfectly centered holes.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
