Old 06-20-2015, 11:44 PM
wfinnell wfinnell is offline
Default Horizontal Stabilizer Mounting
Hi Guys,
I had a visit from a -7 builder today and we had a brief moment of confusion while discussing horizontal stabilizer attachment. I am about to drill the attach holes on my RV-8 and I'm trying to avoid screwing this up (too).
It is my understanding that the RV-7 has the vertical stabilizer mounted at a slight angle relative to the fuselage centerline and on the RV-8 the vertical stabilizer is mounted parallel with the centerline. I believe this is correct, can anyone confirm or deny?
If this is correct, does anyone know why the difference between the -7 and the -8?
Thank you in advance,
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 06-21-2015, 04:18 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Bill, I don't know a thing about the RV-8 but I can confirm that with the RV-7's the leading edge of the VS is offset 1/4" to the left. I marked the centerline on my fuselage and the 1/4" offset on some tape to help with the positioning, at the time when I did this. If the RV-8 is different, I don't know why that would be the case. Perhaps others can comment as well.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 06-21-2015, 04:54 AM
cjhammes's Avatar
cjhammes cjhammes is offline
Default Keep it straight
The 8 VS is kept straight. Offset is integrated with the engine mount.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 06-21-2015, 06:42 AM
Robert Anglin Robert Anglin is offline
Default Been a while..
I do not know about the 7, but this is the way we put the V.S. on the 8 buy the plans and homework done with regard to putting in a little offset.
It is as has been said not needed on the 8. All of my friends with 8's have had no problem with the V.S. being on the centerline, front to back as well...
Yours. R.E.A. III # 80888
Old 06-21-2015, 09:54 AM
rvbuilder2002's Avatar
It is correct.
It is because the 8 came before the 9, and the 9 before the 7. The offset vertical wasn't implemented until the 9.
You could do it on an 8 (I did it on my 6a) but you would have to do a major mod. on the emp fairing
Scott McDaniels
Hubbard, Oregon
Old 06-21-2015, 06:00 PM
Thanks guys! Good to know why difference.
Bill Finnell
RV-8 Fuselage
Tucson AZ
