Old 06-20-2015, 04:36 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Default When should I have my first empennage inspection?
I'm just about to close up the horizontal stabilizer; all rivets are set except the rear spar assembly, which is clecoed in place. Once I drive that first rivet, the horizontal stabilizer is CLOSED... so before I did, I thought I'd get opinions on whether to have anything looked at before I rivet the rear spar assembly in place.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-20-2015, 05:04 PM
Mel's Avatar
Mel Mel is offline
There is no hard requirement for in-process inspections. It is recommended to have a tech counselor inspect your work before you get very far into the build. This will allow you to correct any bad habits you may be starting out with. I recommend you get an inspection before closing up that first part.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-20-2015, 05:41 PM
wirejock's Avatar
wirejock wirejock is offline
Default Inspection
Agreed.
If you can't get an EAA Tech Inspector to visit soon, ask a mentor to check the work before closing the part. After the good news, your inspections can be farther apart. After the empennage is done, before closing tanks, before closing wings and so on.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-20-2015, 09:18 PM
xblueh2o xblueh2o is offline
That is when I had mine inspected.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
