06-20-2015, 05:27 AM
Turning down a bushing
I need to make a bushing to use to attach my alternator to the new brackets I am installing. Bracket accepts a AN5 (5/16") bolt and hole in alternator is 11mm (.45"). I have a 0.5" OD bronze bushing I want to reduce to the 0.45". Any tips on turning down the OD without using a lathe?
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
06-20-2015, 05:59 AM
How long is the bushing? If short, grind down the head of a bolt and a nut then clamp it and use a drill press (OK, a drill works too), file, and sand paper. File across it in a normal manner, don't just hold it against it. Check with dial caliper and when within a few thou, switch to 80 - or 180 grit hardware cloth. Wrap around and move like an old shoe polish action.
Bill
RV-7
Lord Kelvin:
06-20-2015, 08:13 AM
Getting a bushing down to 0.025 thickness will be tricky.
Bad math... it will be about 0.060 thick, still tricky...
How about simply drilling out the hole in the alternator?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-20-2015, 09:47 AM
McMaster-Carr will happily sell you a sleeve bushing, 8mm ID / 11mm OD.
Dale
Omaha, NE
Previous RV-7 project (sold)
06-20-2015, 11:09 AM
If you have a solid bronze bushing it will be machinable. If it is scintered bronze (oilite) it will disintegrate because it is basically compressed powder. If it is a sleeve you want just to take up an empty space and not something that needs to provide a bearing surface for a turning shaft then make it out of mild steel. There must be an EAAer in your area with a lathe. It is a 2 min job.
Scott Black
VAF dues 2020
Instagram @sblack2154
06-20-2015, 11:44 AM
Originally Posted by sblack
If you have a solid bronze bushing it will be machinable. If it is scintered bronze (oilite) it will disintegrate because it is basically compressed powder...
I lathe turn Oillite sintered bronze bushings pretty much every week, and they turn down just fine.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
06-20-2015, 07:23 PM
Why not just drill out the bracket to accept the size bolt that fits the alternator. A grade 8 metric bolt should work just fine.
Jesse Saint
06-20-2015, 08:36 PM
Go the other way
If I didn't have a lathe I would try getting a bushing that was 11mm OD with a small enough ID to drill or ream the ID to correct size. You might get away with a 11mm OD and a 8mm ID. Our local hardware store has a surprisingly good assortment of odd bushings.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
06-21-2015, 07:02 AM
Thanks all for the suggestions. All good.
BillL, This was my first thought as well. It worked great. Clamped bushing with a long bolt and nut, chucked bolt in air drill, duct taped drill trigger, used file and sandpaper. In a few minutes took of 0.05" and ready to go.
I have 3 lathes within a few hangers of mine. Just like doing it myself and got it done before others showed up at the airport. Two guys said they would have done it for me but it was done and installed before either of them were awake. Both offered to give me a check ride on their lathe so I can do-it-myself next time.
It goes through the tensioning bracket which is a long slot and would have had to open the entire 1.5" long slot. Plus Could not open the slot to 0.45" for lack of edge distance.
Went to two of our best local hardware store (not big box stores) that usually never let me down with theses sort of things. Neither had anything close. Could have made the part in 1/10 the time I spent trying to find something closer.
Philip
06-21-2015, 07:37 AM
Thanks, Bob K.
Really? Ok, then u know something I don't
Scott Black
VAF dues 2020
