Old 06-19-2015, 03:39 PM
danielabernath danielabernath is offline
Default RV-12 6 amp or 12 apm charger? Odyssey.
I somehow have acquired a 6 amp and a 12 amp charger for the Odyssey battery. Both have the bayonnet type connector.
I tried the 12 amp but nothing happened. Was my RV 12 trying to tell me something?
Which should I use?
Old 06-19-2015, 05:36 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Which should I use?
The 6 amp charger should work fine for the PC680 in the RV12. After you hook up the charger to the battery then plug it into 110v it then defaults to trickle charge. When the charge button is pushed the charger starts charging the battery and the yellow lights on the panel begin to light up starting from the bottom and climbing to the top until the battery is fully charged. Then after detecting a full charge the charger will automatically switch to trickle charge and the lights go out. If the battery is already fully charged when you push the charge button the charger will sense the fully charged condition and quickly change to trickle charge and skip the charge portion altogether. Is this what is happening in your situation? I assume the 12 amp works the same way.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 06-19-2015, 06:38 PM
I've not been at the airplane for a few weeks much so I'll try it tomorrow morning and let you know. Thanx
