Old 06-16-2015, 06:47 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Tip: Waste less paint!
Dipping with a soup ladle or pouring wastes paint and discourages doing small jobs when needed. I saw the suggestion of plastic lids with spout here on VAF. They were $22 for 4ea on line and you had to buy 8 plus freight if you used gallons and quarts. My local auto paint store had Dedoes paint mixing lids for body shops. These not only snap on the can with elastomer gasket, they have a mixing paddle built in that a drill can turn, PLUS there is a spout that opens and closes like pancake syrup at IHOP ! They cost me $5 ea for quart and a gallon.
I am using Stewart System waterborne paint. I t cleans up pretty easy with water. However, the paint store suggested Water Wave surfactant to clean the gun so the next use doesn't even try to stick. Hope this helps someone.
Decamplarry@gmail.com
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 06-17-2015, 02:27 PM
Boomer506 Boomer506 is offline
I hate wasting paint and primer too. I use Dupont Imron and their Veriprime 615S metal etch primer. For small amounts I will use the stir stick to lift small amounts out of the can and scrape off on the edge of my mixing cup. I can prevent any material from getting into the rim which would prevent a clean seal on closing. And I can mix small amounts quickly and easily. I mix the Veriprime thin and brush it on with a sponge brush. I can mix, apply dry with a heat gun, flip and get the back side, dry again and be ready to dimple/rivet in a very short time. To seal exposed areas of steel weldaments with Imron top coat, I use small disposable hobby brushes.
Sam Bovington
Intruder B/N, Stanwood, WA
RV-6 N934B built, flown and sold
PA-23-150 N2108P restored flown and sold
RV-8 "Bad Blue" under construction
Old 06-17-2015, 03:50 PM
BigD BigD is offline
Here's a picture of one (post #21):
http://www.vansairforce.com/communit...=117770&page=3
==dave==
N102FM
