Baffle part number needed...
Away from my plans and need a part number - anybody have a copy of drawing OP-4 handy?
What I need is included in the O-360 baffle kit, the aluminum piece that stands vertically behind the left rear cylinder and engine case, with the curved section around the bottom half of the cylinder barrel.
I cut an ignition wire opening in mine before I changed my mind to go with a plenum - now that opening is exactly where the plenum edge will be and I need to replace that piece.
