What Kent said seems correct to me;
However, you need to identify the engine some way when you register the aircraft.
I built my RV-8 with a Mazda rotary, so I had to name it and install a data plate on the engine.
After 16 hours of flying that combination, I decided to go Lycoming and joined IAC to do aerobatics. I got a sweeet !! deal on an IVO-360A1A out of a Brantley helicopter. 100 SMOH.
Same as you, many changes: new Superior sump, AFP injection, aircraft gear case, Oil fill tube, feather weight starter etc etc.
I logged these in the original engine log, verified the oil pump AD was complied, and installed a new crank gear just in case there had ever been a sudden stoppage that hadn't been logged.
I then re-named the engine by preceding the model with (X)
(X) IVO-360A1A
That satisfied the FAA when I updated the aircraft registration form, which seems to be the local interpretation for engine and prop changes.
It should serve the future, as the correct IVO-360A1A specific parts that remain can be sourced as required.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
