Hi, I know you guys in US don’t need this device thanks to ADS-B system. I’m located in Europe and we have to wait for such solution several years and I decided to install ZAON XRX.
I would like to locate this device between the engine section and the cabin in a hole like on the attached photo. Obviously the hole would closed by a plexiglas.
Will it work properly in this place?
I saw such solution same time ago on other plane. Other option would be to install ZAON at this place but with the antenna partly protruding outside the skin.
I have found some guys installed ZAON in wingtips or baggage area but I don’t like such solutions.
If you have experience in this area please advice. Thanks. Witold.
Link to the photo if it is not visible above:
https://www.dropbox.com/sc/ffrxwkeqi...Vh6mPSUswy--1a
