Go Back   VAF Forums > Model Specific > RV-9/9A
Old 06-07-2015, 09:55 PM
Mark C. Mark C. is offline
Default RV Bits Main Gear installation fairings
Looking for pictures and ideas how they installed "RV Bits" gear fairings. Final stages of my 9A build. Thanks,
Mark C.
IO 360 Mattituck
Catto-Tri
All Dynon Instru.
Old 06-07-2015, 11:53 PM
bruceh's Avatar
bruceh bruceh is offline
I used the Van's fairings, but they are similar (probably not as nice as the RV bits version).
Photos of my installation here.
I had to trim them down a bit (got rid of the rough edges) and bonded them to the wheel pants.
Bruce Hill
2021 VAF donator
Old 06-08-2015, 06:45 AM
Rupester Rupester is offline
Mark .... are you talking gear leg fairings or intersection fairings?
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 06-08-2015, 08:06 AM
219PB 219PB is offline
Default spring loaded access covers
Bruce<
Where did you get the 1" spring loaded access covers for your tire valve stem on the main gear?
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 06-08-2015, 09:52 AM
On the gear leg, top and bottom. I want to use screws and nutplates to hold everything together. I have seen builders have cracks at the mold spot to the wheel covers after many landings.. Mark C.
Old 06-09-2015, 07:33 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Here's my journal entry for installing those and a couple of photos. Hope it will help some.
http://www.aclog.com/rv-9a/index.php?c=5#1195
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-09-2015, 12:50 PM
bruceh's Avatar
Access doors are from Aircraft Spruce
CAMLOC ACCESS DOORS FOR WHEEL (KM713-16-064)
Bruce Hill
2021 VAF donator
Old 06-09-2015, 11:02 PM
Mike, very nice pictures and write up.. After a couple of years flying still no cracks?? By the way when you centered the "fairings" to the belly of the aircraft and wheel pant, did you have the wings on? Mark C.
Old 06-10-2015, 05:11 AM
I fiberglassed the lower intersection fairings to the front half of the wheelpant. It makes removal fast and easy. No cracks after 2.5 years. the upper intersection fairings look much like Mike's ....I used platenuts in all but one location (on each side) where I used a keyed rivnut.
I'll have to look for pics ....
Terry Ruprecht
Old 06-10-2015, 05:40 AM
mikehoover's Avatar
No cracks so far. I did have my wings on and flew without the fairings for a while. It was a pain to install the wheel pants and gear leg fairings with the wings on. It'd be much easier to install them without the wings in the way.
Mike Hoover
Columbia, SC
www.eaa242.org/
