Old 06-06-2015, 12:50 PM
ethand ethand is offline
Default ACK 406/121.5 MHz E-04 ELT Length
Working on my ELT tray install and hoping someone can tell me the overall length of this unit with battery (several years from flying and have not purchased the ELT yet)
I see in the installation instructions it lists length as 7.75" but then lists the battery separately at 5.75".
Is the overall 7.75 or 13.5"
Thanks in advance
E
Old 06-06-2015, 06:21 PM
SMO's Avatar
SMO SMO is offline
7.75"
If you look at the picture on page 16 of the manual it should become clear that the ELT portion is less than half the length of the battery.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 06-06-2015, 06:29 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
The battery plugs into the side of the unit and exists within the overall dimension of the unit - the 7" dimension sounds right. See here: http://ww.mykitlog.com/users/display...=165635&row=17
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 06-06-2015, 06:43 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
And as a cross-check the IM says the straps are mounted on screws 5.5 inches apart.
7.75 is correct...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-06-2015, 08:53 PM
Thanks for the replies.
Based on the diagrams and install I assumed it was 7.75 but wanted to confirm as I am space limited
E
Old 06-06-2015, 09:21 PM
bruceh's Avatar
bruceh bruceh is offline
You'll need to leave some room on the head end for the wiring.
Bruce Hill
2020 VAF donator
