Old 06-04-2015, 08:04 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default Rising CHT, Lowering EGT
I recently completed my CI and did a test flight today. Everything seemed all normal at first. As I climbed out of the pattern and into 3000 I quickly noticed engine roughness. Then looking at the engine gauges I saw number 2 cylinder CHT rising through 400 and the EGT dropping to about 1000. I quickly reduce power and headed back to the airport. Upon descending to about 2000 ft the temps came back to almost normal (although #2 egt was about 100 degrees less than the others which isn't normal). I landed pulled the cowl and visually inspected everything. Saw no visible issues so I put the cowl back on and tookoff. I stayed above the airport. And again upon climbing to 3000 ft egt dropped and cht rose... Landed again.
The only thing I did during the CI was change the intake gasket. Thinking that was a good idea for some reason. I only had 2 gaskets on me, so I changed number 2 and 4 intake gaskets. (before I ordered more gaskets someone told there is no need to proactively replace these gaskets, so I did not change 1 and 3)
My thinking is I have an intake leak most likely from the gasket. Is my thinking correct here.? Climbing in altitude is causing more air to leak and thus lean out the cylinder... ??
thanks for the help.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 06-04-2015, 09:34 PM
Hard to say without knowing where the mixture was. If full rich then an induction leak would lean it, and EGT would rise, not fall. Altitude would not matter, but throttle position would. Full throttle and the induction pressure is close to ambient, so little extra air is drawn in. Part throttle, induction pressure is lower, it should suck more air in thru a leak. That doesn't sound like what you described. I'd pull the plugs and look at them. Any evidence of a hot spot causing pre ignition?
Old 06-05-2015, 04:41 AM
miyu1975's Avatar
Hard to say exactly where my throttle and mixture were and my data logs didn't download correctly. Going off of memory I believe I was about 24/2400 and I had only slightly leaned the mixture when #2 temp issue occur (so it would have been pretty rich). I did enrichen at first sign of high CHT but that didn't seem to help. I also recall what did help was pulling the throttle way back.
Ryan Allen, CFII
E-170/175
Old 06-05-2015, 05:05 AM
miyu1975's Avatar
Some more VAF searches I am thinking maybe I have pre ignition issue too... Guess I will take a look at the plugs and retime my P Mags.
"Pre-ignition is the initiation of the flame front BEFORE the planned spark ignition event. It is a normal flame front, just started too soon. As opposed to detonation where EGT is little changed, pre-ignition results in rapidly falling EGTs and rapidly rising CHTs." walter Atkinson
Ryan Allen, CFII
E-170/175
Old 06-05-2015, 06:47 AM
Smilin' Jack Smilin' Jack is offline
Ryan, check your injectors. A little trash in one and I mean a pin head size will cause a lot of sudden roughness
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 06-05-2015, 08:34 AM
Lenny Iszak's Avatar
Lenny Iszak Lenny Iszak is offline
Yep, that sounds a lot like preignition. A partially clogged injector should spike the EGT, because of a leaner mixture.
Intake leaks show up at low manifold pressure. Manifold pressure is actually a vacuum at low MP and ambient air at high MP. There's no reason for air to go through the leaky intake seals when the tubes are open to nearly ambient air pressure.
I would check and even replace the plugs in that cylinder, and borescope it.
Sometimes the ceramic insulator is cracked and it's not visible.
What type/brand plugs are you using? Apparently Champions are notorious for cracked insulators.
Can you try downloading the data again from your engine monitor?
I'm sure those with vastly more knowledge will chime in here shortly, I just want to make sure you are concerned enough to not go flying it to see if it goes away, cause if it is preignition it won't be pretty
Old 06-05-2015, 08:43 AM
tim2542 tim2542 is offline
Default Ignition wires?
Assuming ignition for the moment, see if you can isolate which ignition is bad, turn one off at a time and see which one is causing the problem. If you find one system bad, swap out the #2 wire on that system onto another cylinder (or system) and see if the problem travels with it.
If misfiring the egt would go up when one system went dead (misfire or short to ground of a single wire, or one system turned off) , if cross firing the spark can jump onto another lead and who knows where it goes, but it can fire the wrong cylinder at the wrong time, so don't mess around too long with your testing.
Higher altitudes will stress the system and may be why you don't see it on the ground. You can test the leads resistance and see if it meets spec in the the Pmag manual, but you can also have an insulation breakdown, and that won't show up on the ohm meter.
Tim Andres
Old 06-08-2015, 05:56 AM
miyu1975's Avatar
Ok, I have a theory that came to me last night while looking over the troubleshooting Lycoming guide.
One topic was, "Cannot reach specified Altitude" Cause "Dirty induction Air Filter"
This got me thinking. I did clean and reoil my k&n filter. The recharge kit I bought this time came with a squirt bottle of oil, rather than the spray can I was used to. Because of this I way way over oiled the filter. After it set for a day or 2 dripping oil I wiped it clean then installed on the plane. Then a day or 2 later noticed red oil dripping from it so I removed, washed and lightly oiled again.
So my thought is that it is still over oiled and the engine cannot get the air it needs. This would explain the engine roughness while climbing. The more altitude is going to put it more and more lean. Yes number 2 cht was the highest but #3 wasn't far behind. I have the Rod Bower ram air set up. So I can easily test this theory and open the butterfly valve and fly filterless.
This would also, I believe, explain the excessively wet spark plug on #2. It's getting fuel, spark, just no air at altitude...
Any thoughts on this?
Ryan Allen, CFII
E-170/175
Old 06-08-2015, 06:31 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by miyu1975 View Post
So my thought is that it is still over oiled and the engine cannot get the air it needs.....I have the Rod Bower ram air set up. So I can easily test this theory and open the butterfly valve and fly filterless. Any thoughts on this?
When running with the butterfly closed, the RB reed valves are likely to be far more restrictive than any amount of oil in the filter.
Did you inspect the plugs?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-08-2015, 06:35 AM
Danny King's Avatar
Danny King Danny King is offline
Default Intake gasket
If your new intake gasket is leaking, then your symptoms are right on. Been there done that. Pull the intake tube again and make sure the new gasket is seated correctly. An air leak at either end of the intake tube will case what you experenced.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
