Old 06-04-2015, 06:03 PM
RVamigo RVamigo is offline
Default Bad Rivet-What is the reason?
Hi Guys!
Couple years ago I built already an RV.
Now I have a new project and have problems with rivets and stopped working until I get a solution for my problem that I never had before.
Here is a picture of this bad rivets.
[IMG]Bad_Rivet.jpg[/IMG]
Does somebody know the exactly reason why that happens?
Using a 3X Rivet Gun with 30 PSI. Hard pressure on the gun, moderate pressure on the 2lbs bucking bar.
Paulo
Paulo
Building RV-7
Old 06-04-2015, 07:18 PM
wirejock's Avatar
wirejock wirejock is offline
Default Photo
Originally Posted by RVamigo View Post
Hi Guys!
Paulo
Can't see the photo.
Edit
It looks like a proud rivet. The cause is there is more pressure on the bucking side just before the shop head swells enough to hold the rivet in place. Push harder on the factory side and less on the bucking bar.
Here's the photo
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-04-2015, 07:40 PM
N941WR's Avatar
N941WR N941WR is offline
I learned that using riveting tape on every rivet was a big help in keeping them from backing out.
Should you get one that stands up like that, sometimes you can push them back into place with a spring loaded center punch, if they are not overly set.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-04-2015, 10:22 PM
fl-mike's Avatar
fl-mike fl-mike is offline
The dimple looks a bit "un-crisp" also, i.e. under-dimpled.
Mike W
Venice, FL
N164WM
Old 06-05-2015, 04:20 AM
Tom Martin Tom Martin is offline
I do not think that the hole was dimpled and that the original poster perhaps thought that the riveting process would "make" the dimple. Just a guess.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
