I am not affiliated with this company whatsoever. However, if you're using fluorescent lighting in your shop or hangar, these bulbs are the stuff.
I bought 50 and they are nice and bright! Very pleased!! I bought the ones that wire directly to the 110VAC, bypassing the ballast. They are easy enough to install using your good judgement. I put them in the existing 2'x4' ceiling tile troffer fixtures in my shop.
Using these cuts the amps required in half. Now I can run all the lights at once without popping the breaker like it used to occasionally do. And run them 2x as long for the same utility cost!
These are every bit as bright as the 40w T-12 bulbs that they replaced. Probably much brighter to be honest. 1800 lumens is more than enough per bulb.
https://www.earthled.com/collections...ant=2174807620
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
