Old 06-02-2015, 05:29 PM
price@heartland-mfg.com price@heartland-mfg.com is offline
Default wing rack/jigs for 9 wings
Getting close to starting on my -9 wings and need to know what I need to build for jigs/fixture/stand or whatever etc?
Can someone point me toward some plans that will cover all the bases?
Old 06-02-2015, 06:01 PM
wirejock's Avatar
wirejock wirejock is offline
Default Jigs
It depends on your shop. If you can drill the floor, these are pretty awesome.
http://www.vansairforce.com/communit...ead.php?t=5058
If you want or need to stick with wood, there are lots of options. A friend of mine built his from 4"x4". Basically a big frame. The only thing fixed is the vertical joists are glued to the floor.
As far as a stand, the Vans design works fine but there are lots of options there too. I used the Vans plan and it works. Pics in my blog.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-02-2015, 06:16 PM
N941WR's Avatar
N941WR N941WR is offline
I know of one -9A that had its wings built on sawhorses with no ill effects.
When I built mine in my basement, the floor joists above were exposed so I secured the tops to the joists and made some simple "feet" to keep the bottoms from moving.
Also, I did not use 4x4's but rather screwed 2x4's back-to-back to help prevent warping.
There is more detail here.
I found that the pre-punched kits are so well engineered it would be very difficult to rivet a twist into the wing. Still, when it came to match drilling and riveting, I started in the middle of each panel and worked outward.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
