Old 06-02-2015, 12:07 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default Tosten grip wiring question
I am considering installing the new military tosten grips and had a quick wiring question. One of the options on the grip is to add a switch that can be used as a flap switch. I would like to wire the grips flap switch and keep my current flap switch on the panel. Does any know how or what this would req?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 06-02-2015, 12:14 PM
Raymo's Avatar
Raymo Raymo is offline
If you don't already have a flap relay, this one will work. They also sell a 3 axis relay that will control flaps, roll and pitch trim on one board.
There are ways to wire the switches such that one switch will disable another that is activated at the same time but the relay, IMO makes it easy without the head-scratching.
EDIT: The Vertical Power box will also act as the relay, if you have one.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 06-02-2015, 02:13 PM
deene deene is offline
As Ray noted, you will need a relay board (or two 12v relays) to implement multiple switching for the flaps. You cannot simply parallel the Vans switch and the grip switch without using relays.
I just finished a RV-7 panel and implemented what you requested. I also used the referenced relay board. An added bonus is that the board has the relays needed for roll and pitch trim operation. Good instructions come with the board, so you should have no problems.
As a side note, I always implement parallel switching for stick grip switches to handle any stick grip problems and also allow copilot activation.
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 06-02-2015, 07:31 PM
miyu1975's Avatar
Thanks. I will look into the relays.
Ryan Allen, CFII
E-170/175
Old 06-02-2015, 07:41 PM
beberle beberle is offline
I'm pretty sure I purchased my relay board from Tosten when I bought the grips. You should check out their site...
______________
Brian Eberle
RV-6A
KFFC
Carpe Diem!
Old 06-03-2015, 07:22 AM
Raymo's Avatar
I am going with Infinity grips and they sell the same relay as I mentioned above. Tosten may do the same.
Ray
Old 06-04-2015, 07:39 AM
Snowflake's Avatar
Here is one relay board option (no experience with this, just posting as an example of what's available):
http://www.aircraftspruce.ca/catalog...ickkey=1511473
Rob Prior
