Old 05-31-2015, 03:07 PM
turbo's Avatar
turbo turbo is offline
Default water in the static system
the plane went thru a few strong storms in st pete fl last weekend. the end result was a vfr departure with the vsi and altimeter all over the place. when i got home i pushed back from the static line near the panel area and saw a few drops of water exit the static port. sure glad it was a vfr flight. any ideas on installing a cockpit alternate static port hookup? always learning.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 05-31-2015, 03:09 PM
Stein sells a nice little hydraulic valve that looks like a toggle switch.
Old 05-31-2015, 03:34 PM
turbo's Avatar
bob, thanks, i checked it out.
Ed D'Arcy
Old 05-31-2015, 04:00 PM
aerhed aerhed is offline
The safeair toggle is nice. Piper used to favor a Curtis valve. Other guys say they know where the line is and would cut it with a knife.
Actual repeat offender.
Old 05-31-2015, 05:54 PM
terrye terrye is offline
Default Clippard TV-2SP
I'm using a Clippard TV-2SP pneumatic toggle valve.
http://www.clippard.com/part/TV-2SP
Also using a Clippard 15070 stainless steel muffler, not for the noise, but to have a filter on the open port so critters don't get inside.
http://www.clippard.com/part/15070
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 05-31-2015, 06:10 PM
Ironflight's Avatar
VAF Moderator / Line Boy
All of our airplanes have tubes "T"ed off both pitot and static that are tucked up under the panel and used for transponder/static system testing. They have Stein's QD's on the end, with plugs in them. Easy to pull them down and remove the plug in flight (we use orange tubing for pitot, clear or white for static, so identifying the static line is easy)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-31-2015, 06:22 PM
gasman gasman is offline
A leg from the static line behind the panel down to the panel edge just out of site with a simple valve attached can act as a test port and alt. static source.
You may be surprised how little difference there is between your exterior static port and one that you open in the cabin.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 06-01-2015, 08:52 AM
Paul K Paul K is offline
I have the toggle and it works great.
You might be in for a surprise if you open the toggle in flight and you are using the auto pilot! Everyone should try this just to know what to expect!
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 06-01-2015, 02:40 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
I had a similiar thing happen to my Navion, only it had been parked overnight when it rained. When I took off, the Altimeter & VSI were really jerky. The static system layout in the tail is the same as Van's. After landing, I very gently sucked on the static openings and was surprised how much water came out.... (both sides). It was obvious the static ports/lines worked by capillary action and drew water inside the lines during the rain storm.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 06-01-2015, 03:38 PM
Finley Atherton Finley Atherton is offline
This happened to me conducting an approach in heavy rain during my IFR training. Instructor next to me so no real problems.
I can't recall exactly what happened but I am sure the Skyview ATTITUDE display became jerky and unusable (Skyview attitude uses static input) - sure gets your attention approaching minimums in cloud and rain. Went to the backup MGL Extreme Mini which does not use static input for attitude display.
I have since installed alternate static air and replaced the Vans static ports with Cessna style ports which I think are less susceptible to water blockage.
Fin
9A
