05-30-2015, 06:21 PM
Mounted my wings on the fuselage. Yay! But my wings sweep forward 1/8"
Hi all
Ok mounted my wings. my rear spares are all the way against the fuse. and yes I used a flush 1/8" rivet above where the rear spare is. So no interference with rivets. But my wings sweep forward 1/8". I am thinking the only way to remove the sweep is to take the wings off and file the rear spare down say 1/32 or 1/16. But before I do that I wanted some feed back. So, is it ok to file the rear spare? Thanks Joe
05-30-2015, 07:05 PM
Yes it's okay to do that. Just go slowly because it won't take much filing at all. There was another thread along these lines not too long ago if you want to do a search.
BTW, 1/8" sweep is within Van's tolerances. But you can get as close to spot on as you'd like. Just keep in mind the potential damage that might happen if you're going in and out with the wing bolts repeatedly.
David Welsh
Beaumont, TX
RV-7 N413WD
05-30-2015, 07:08 PM
Did you trim the rear spar per the plans?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
05-30-2015, 07:18 PM
See the thread started by jacksel on 1/9/15. Much of the same experiences.
David Welsh
Beaumont, TX
RV-7 N413WD
05-30-2015, 07:22 PM
yes trimmed the spares per plans. Joe
05-30-2015, 09:54 PM
Be careful. Removing 1/8 inch off the rear spare = 1 inch of sweep at the outboard end of wing. Larry
05-30-2015, 10:09 PM
1/32"
You'll probably only need about 1/32" removed from each drag spar. That should bring them into alignment. Very common issue that is easy to fix.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
05-31-2015, 02:39 AM
I find it difficult to believe that 1/8 th of an inch forward sweep would make any detectable difference. The end of the wing is, what, 9 foot out from the fuse?
Phil
LAME (Aust)
RV7 99% finished
05-31-2015, 04:50 AM
I trimmed mine a bit, as suggested, and my little bit of forward sweep was corrected easily.
05-31-2015, 05:06 AM
Nope
I'd leave well enough alone...you'll never know it.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
