05-28-2015, 09:54 AM
Compression: engine cold vs engine hot
What, if any, difference can there be between compressions you measure when the engine is cold vs when the engine is hot?
Should they be identical? Close?
thanks
Flying RV-8 N880BC
2019 Dues - happily paid.
05-28-2015, 11:16 AM
Super Moderator
Typically better
Usually, but not always, they will be higher when hot. But a good engine should test OK when it is cold. I typically see compressions in the 70's on cold engines all the time, and never retest hot unless one is really different or substantially lower, such as in the 60's.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
05-28-2015, 12:13 PM
Vic
Hi Vic,
In the airplane I'm considering, the owner says the compression is in the 60's when cold but mid 70's when hot. Exactly like your scenario above.
What does this mean? Is that a cause for concern?
thanks!
Flying RV-8 N880BC
05-28-2015, 01:22 PM
Super Moderator
Should check other things
With a gap like that it may not be a cause for concern IF you check the following:
Do the compression tests and see where it is leaking (rings or valves)
Is th eaircraft on an oil analysis?
How much oil is it burning. Burning NO oil is bad for aircraft engines. They are meant to burn some oil.
Be sure to check screen and cut open the oil filter.
If possible, download the engine data from the EMS and check for operating temps.
Call if I can be of help.
Vic
404-307-5133
 Vic Syracuse
