Old 05-26-2015, 06:29 PM
olyolson's Avatar
olyolson olyolson is offline
Default Broken NACA vent- need advice
The rear NACA vent stem broke from the knob and I can't figure out an easy fix. Can I order a new vent and scavenge the parts I need? Any other ideas?
Need help, pics attached,
Oly
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 05-30-2015, 08:13 AM
olyolson's Avatar
Default Broken Vent
No response, guess these things don't break often. Anyone have any of these vents from a project or parts bin? I may be able to salvage the parts I need to make mine work. I was able to secure it in the closed position with a countersunk screw threaded though the inner shroud but would like to be able to have the back seater open the vent as needed.
Let me know if anyone has a complete assembly or whatever parts you have.
Oly
RV-8, Flying
2018 dues paid
Old 05-30-2015, 09:29 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I could be wrong, but I think that is a custom part, or somethign I haven't seen sold by anyone for a long time - that might account for the lack of responses. I don't THINK it was ever a Van's part.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-30-2015, 11:10 AM
BillL BillL is offline
It looks like a standard part from a Velocity = http://wiki.velocityoba.com/index.ph...e_Heat_Control
Why don't you just fix it. Click bond makes some glue on studs. Doesn't look too hard.
Bill
RV-7
Lord Kelvin:
Old 05-30-2015, 07:06 PM
Billvt's Avatar
Billvt Billvt is offline
Default Try PLASTIC SUPER GLUE 386855
I had my NACA vent shaft break and glued the shaft back with plastic super glue 386855.
Comes with a liquid primer to condition the plastic. The glue itself is a gel.
The vent broke at 36 flight hours and I now have 908 hours and it is still working.
Regards,
Bill
Bill Morelli - A&P I/A - EAA Tech Counselor
Up North Aviation
CNC Instrument Panel Fabrication
Web www.upnorthaviation.com
E-Mail upnorthaviation@gmail.com
- RV-4 build in progress !!!
Old 05-30-2015, 08:33 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Those look like canard parts, no longer made. There was a repair kit available for some time but gone now.
I have a complete spare I'm saving for "some day"....
Like others suggested, work out a repair for the shaft. Homebuilt fabrication......
Old 06-01-2015, 06:48 AM
olyolson's Avatar
Default Broken Vent
Thanks for the tips, I think I might have found a plastic threaded stud from Click Bond that might work. If it is the right size, will thread it through the inner shroud and glue the stud to the outer vent door. I do have it locked in the closed position right now but obviously want to have it operational for the back seater. I do have an LV-3 type ventilator in the back as well so there is a decent amount of air flowing. In the hot, humid Missouri summers, more air is definitely better.
I would have just glued the old stud in place but it came apart in 3 pieces and had a lot of stress cracks and deterioration in the plastic stud. If it works, I will post pics and info on the part number in case anyone else has the problem.
Oly
RV-8, Flying
2018 dues paid
