Old 05-25-2015, 06:52 PM
riobison riobison is offline
Default Help My Vans Oil Cooler Shutter wont stay open
My Vans Oil Cooler Shutter http://vansaircraft.com/cgi-bin/stor...ct=oil_shutter keeps creeping shut in flight. Would anyone have any suggestions on how to put a little more friction into the cable? I'm using a basic push pull carb heat cable. I've tried putting some silicone into the end of the cable, some silicone on the part of the guillotine slide but the stuff does not stayed glued. As well, I have tried crimping the outer casing but that stuff is hard and I have a feeling it will be all or nothing so I stopped.
Any other suggestions?
Tim
Old 05-25-2015, 08:52 PM
bhester's Avatar
bhester bhester is offline
Default Right cable?
Are you using the right cable? It should have a ratcheting feel as you move it in and out.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 05-25-2015, 09:14 PM
bruceh's Avatar
bruceh bruceh is offline
Ditto. I bought the oil cooler shutter and cable from Van's and the cable has a ridged end that will hold it in place.
Bruce Hill
2020 VAF donator
Old 05-25-2015, 11:46 PM
Unhappy
The cable that's in there is a ratcheting cable, but not much of a ratchet at the moment.
Old 05-26-2015, 04:02 AM
rzbill's Avatar
rzbill rzbill is offline
I had the same problem with the ratcheting cable on my cabin heat. I replaced the cable with a button lock style (no not a vernier) from Spruce.
Bill Pendergrass
ME/AE '82
