Old 05-24-2015, 01:34 PM
prkaye prkaye is offline
Default source of brake caliper bleed valve
Anybody know where I can get a replacement bleed valve for the standard RV-9A brakes?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 05-24-2015, 03:28 PM
lr172 lr172 is offline
I don't know the size of the bleeder used on those brakes. but, Napa has a good assortment. You can take the bleeder off the other calipar and bring it to a napa store to see if they have one. If you have a thread pitch gauge, you should be able to identify the good one and find another one on-line.
So you know, it is not a valve, just simple flared screw with a hold drilled in the center.
Old 05-24-2015, 03:34 PM
Vonsmallhousen Vonsmallhousen is offline
Goto theMatco website type in Bleed in the search. They are under 4 bucks
www.matcomfg.com
RV7 ZK-DVS
Whangarei
New Zealand
EMS S76 Pilot
Old 05-24-2015, 03:35 PM
AltonD's Avatar
AltonD AltonD is offline
From Spruce
http://www.aircraftspruce.com/catalo...500x5brake.php
part #8
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
