Old 05-22-2015, 08:45 PM
Sierra Delta Sierra Delta is offline
Smile Aveo Rockrack master battery switch
I'm in the middle of completing a 9A build. I have a set of Aveo Rockrack switches, purchased several years ago. My question concerns the wiring arrangement for the master switch. Eight terminals on the switch, but I'm not sure where to place the wires from the Master Relay, fuse panel (power) and ground. Anyone used this switch for the Master Battery? Also, the engine is an O-320, with two Slick mags. The alternator is a Plane Power 60Amp version. Any help would be greatly appreciated.
Sierra Delta
