11-13-2006, 05:42 PM
Fuel Tank skins: dimple or countersink?
I ask because I'm about to dimple a tank skin, and I can't reach the forward most holes with a C-frame (DRDT-2), so I countersunk them. I can't (won't) C/S the whole skin, since I already dimpled the ribs, but it sure makes for a perfectly smooth surface! Would a wholly countersunk tank be strong enough?
On the one hand, the skin is plenty thick for countersinking, and then it would be "glued" (pro-seal) and riveted. On the other, you have the locking action of the dimples...
For those 10 countersunk holes I plan to flatten the rib dimples out tomorrow by squeezing with flush sets. Is there any reason I shouldn't, and would be better off leaving the dimple?
Johnny Pruett
VAF #601
-9 fuselage standard kit on hand
Slooow build wings still in progress...
11-13-2006, 05:55 PM
If you've already countersunk the skin, I'd mash the rib dimple flat.
As an aside, I use a drdt-2 and had no problems at all reaching all the holes in the skins. I assume you had the male die in the ram and the female die on the anvil. That way the tank skin is dimpled with the outside of the skin facing upwards. The other way does cause a lot of interference with the handle.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
11-13-2006, 06:27 PM
I dimpled all the holes in the tank skin with the DRDT-2 with no trouble ... ditto on the male die on the top...
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
11-13-2006, 07:18 PM
work bench dimple machine
I had a few that I couldnt reach on different skins so what I did was drill a 3/16 hole in my particle board work bench and then I stuck a the male die in it and I had a piece of 1/2 round stock with a 3/16 hole in it line it up and hit it with a hammer worked good. I also had the pop rivit dies for some hard to get to areas
Jim Knight
Burlington Iowa
RV-6
130 hours
01-21-2007, 05:24 AM
Tank Dimple Die
I'm getting close to dimpling my tank ribs and skin. I bought new tank dimple dies and would like your experience to confirm that I should use this die set for both the skin and the ribs.
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
01-21-2007, 05:37 AM
I used them for both the ribs and the skin and all turned out well.
T.
Thomas Short
01-21-2007, 07:53 AM
Speaking of Tank Dies
Bob Avery of Avery Tools took a tank die and welded it to a set of vice grips for me. I use this for that little extra indentation on the underside of flaps and related ribs for areas that require blind rivets. This helps the rivets sit flush to the skin. I have heard others just ream the hole a little.
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
RV 10 - 313RT
Beechrv9a@hotmail.com
01-21-2007, 08:15 AM
Johnny,
A thread I posted a few weeks ago illustrates an easy way to access the forwardmost holes on the fuel tanks with the dimpler.
http://www.vansairforce.com/communit...ad.php?t=13700
That said, because the tank skins are .032 I DID machine countersink the upper surfaces of the fuel tank skins on my 6A. I took a slightly different tack using a rivet shaver because .032 is barely thick enough to accept a machine countersink. http://www.vansairforce.com/communit...ead.php?t=2322
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
01-21-2007, 11:37 AM
Talking to a guy two did CS some of his skins, he told me not too. After 1000hr or so, they started smoking a little and stuff. Looked realy good initially though. I therefore won't be CS any of my skins.
RV4 wing in Jig @ KPOC
RV7 emp built
