Old 11-13-2006, 12:21 PM
BillC BillC is offline
Question Induction Air By-pass control
OK,
I've installed the trap door on the induction system for alternate bypass air, but where have people been installing the control cable in the cabin? I don't really want it taking up space on the panel. Thinking about attaching it to the F902 vertical bulkhead on left side with angle bracket. Anyone out there done this mod and if so where did you place the control?
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 11-13-2006, 04:12 PM
kentb's Avatar
kentb kentb is offline
Smile Hello Bill
I placed mine on the same bracket as the other engine controls. The "emergency air" is located as high and left as I could make it fit and still work. I also filed the sides to square it so that it would have a unique feel. I located the "alt air about 1.5 inches to the right and down. Then comes the throttle, prop and mixture. There is not room left. My cab. heat is located over to the right, close to my passanger (she want to keep warm).
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 11-13-2006, 04:18 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Give due consideration to when you will really need it. What will be your "state of mind" when the engine gets quiet--------calm, cool & collected right??
Make it easy to find, and recognize. Forget aestetics.
Fly safe.
Mike
Old 11-14-2006, 12:45 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Just food for thought
I put mine near the other engine controls in plan view, in a cluster, throttle, mixture, prop and carb heat, with the fuel pump switch not too far away. Why? Traditional, convention, standard panel and control lay out? I know its old fashion and boring, but I just don't think one push-pull takes too much room and if you ever sell it, it will be more logical for most GA pilots.
Also since all the cable controls are coming off my Carb & airbox and going through the lower center firewall, it makes sense to run straight up to the middle lower part of my RV-7 panel. To go off to one side or the other so you don't have to look at it, really is a serpentine routing of the cable. My old worn out advice, follow the plans and keep it simple.
With that said there is no technical reason you can't place as you like, just consider convention for convention sake. Not shot gunning engine controls but clustering them, even a minor one you may not routinly use, has merit.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 11-14-2006, 01:08 PM
Davepar's Avatar
Davepar Davepar is offline
I attached mine to the bottom of the panel, right next to the throttle quadrant. I agree with the paniced state of mind:
RRRrrrr (silence)
"What the... why is the engine stopping. (Looks at throttle quadrant.)
The levers are in the right position. Maybe I'll try this little 'alternate air' thingy."
rrrRRRZoom
Dave
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 11-14-2006, 10:54 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I use some brass Reed valves on the air filter body. Ram air keeps them closed normally. If something restricts the inlet, they automatically suck open giving alternate air. Simple, light, foolproof, no cable required.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 11-15-2006, 09:33 AM
Thanks for the thoughts and input guys,
Looks like I'll relocate my cabin heat control, which is currently to the right of the mixture control, and put the emergency air control there. That way it's close at hand.
Since I didn't get but a few replys to my earlier question, I'm wondering just how many people have even installed the trap door either in a new install or replacement for magnetically latched design?
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 11-15-2006, 01:29 PM
rscott5559A's Avatar
rscott5559A rscott5559A is offline
I installed the trap door in mine. Came in the firewall kit. Haven't installed the cable yet but, will put it near the other engine controls. Note: Did you install some sort of gasket between the filter plate and the air box housing? Looks like it could use a rubber gasket ( .125 ) thick to help seal and keep out dirt.
Robert Scott
RV9A
Finishing
Old 11-15-2006, 02:04 PM
Hi Robert,
No, I hadn't thought about a seal on the plate but now that you mention it, it might be a good idea. I'll have to see what can be done, but must be careful about securing it so as not to ingest it. The plate is a fairly tight fit when in the closed position so 0.125" would be way too thick.
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 11-15-2006, 03:01 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I put pro-seal between the plate and airbox. The knob is on the right lower side of my 6A panel, with a warning sticker, stating emergency only, and must be manually reset.
I see no need to place this knob by other engine controls. I wouldn't care to pull it out accidently, instead of grabbing the prop or mixture; as it's somewhat of a pain to reset.
