Old 05-18-2015, 11:03 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default Tip: Plexi/Fiberglass Cutting Wheel
If you want a cutting wheel for your Dremel Tool that will go through fiberglass and plexiglass like the proverbial "hot knife through butter", go get the Dremel 506CU Premium Metal Cutting Wheel. See http://www.dremel.com/en-us/Accessor...aspx?pid=506CU for more info.
I bought one of these and used it for finish trimming my canopy, and it cut through in one pass easily. I had used Vans cutoff wheels for the earlier trimming and what a difference it made. Highly recommended. I wish I'd had this earlier!
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 05-18-2015, 11:30 AM
wirejock's Avatar
wirejock wirejock is offline
Default Cut off wheel
Thanks. I just ran out of the reinforced wheels. I'm going to buy some of these next.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-18-2015, 11:40 AM
They are made of metal...I'd buy only one at first. I expect mine to last a long time with the abrasive they have on them, plus they're not cheap!
www.marksrv8.com
Old 05-18-2015, 03:50 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Thank you for the tip! I start canopy trimming after the holiday weekend.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
