Dropping throttle, but relatively the same RPM, that yields significantly higher oil pressure is troubling. On the surface of this, under load the crankshaft orbits in the bearings, that orbit will allow more oil to flow than idle at the same RPM. As throttle is dropped the crank main bearing loads are lessened and the crank will be more centered. If there is 10-15-20 psi increase, (at same RPM) that should trigger some further inspection. I would immediately check crankshaft end play and take the oil filter off -check for metal, then remove the suction screen and also check it for metal. Maybe - oil filter, screen, then crank in rank of easiest to do.
edit: if only 85 to 89 PSI that is not significant, and not an abnormal reaction.
Bill
RV-7
Lord Kelvin:
