Old 05-13-2015, 08:57 PM
Charles in SC Charles in SC is offline
Default Trutrak autopilot GPS question
This question may seem dumb to some but I think some one here answer it in a heart beat. I am installing my Trutrak ADI Pilot II that I bought 4 or 5 years ago. It requires an RS-232 signal from a GPS. I want to use a hand held GPS like a Garmin 496 maybe. The problem is that I have never actually seen or held one of these in my hand and do not have access to one unless I buy one which I do not need just yet. So to the question.
Do the current handheld GPSs have output plug sockets on them so you can connect a cable?
Thanks in advance!
RV 7
Old 05-13-2015, 09:07 PM
rv7charlie rv7charlie is offline
https://www.google.com/search?q=Garm...496+data+cable
Most will, but you need to be specific about brand/model to know for sure. Just google 'brand x model y data cable'. That's what I did for the link above.
Old 05-14-2015, 05:48 AM
Abbygirl1 Abbygirl1 is offline
Default cable
This is the one I used for my 196. The data wire ouputs WAAS RS232 info. Handy.
http://www.ebay.com/itm/Bare-Wire-Po...item5403b9b459
Dad of an Air Force C-17 flight instructor
Old 05-14-2015, 06:00 AM
Jesse's Avatar
Jesse Jesse is offline
The Garmin handhelds do output NMEA information in an RS232 data stream. You will need a data cable to do that. For the 296/396/496 units, you can buy a cable that gives power and data output so you can have the GPS hard wired into your plane. It won't give GPS Steering, but it will provide GPS Nav, which is all the ADI Pilot can use anyway.
Jesse Saint
Old 05-14-2015, 06:13 AM
Mel's Avatar
Mel Mel is offline
I drive my TruTrak Vizion 380 with a Garmin 495.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-14-2015, 06:16 AM
Caveman's Avatar
Caveman Caveman is offline
I had a 496 connected to my ADI Pilot II before upgrading to a 796. The 496 will drive the auto pilot great. And yes there is a cable that fits a socket on the unit. This makes the 496 easily removable from the panel if you have an Air Gizmos panel dock. IIRC you have to buy a separate cable from what comes with the 496 originally, but check me on that.
Joe
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
