Old 05-11-2015, 04:36 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default TNC right angle connector
While installing a TNC connector on some RG400 cable, I messed up the pin. Does anyone know of a source where I could buy only the pin? I hate to buy another connector just for the pin. The Amphenol part number is 031-2381. Thanks in advance for any help from the board.
Steve
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-20
www.mykitlog.com/skyking90200
Old 05-11-2015, 05:04 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Check with Walt http://www.expaircraft.com/ or Stein http://www.steinair.com/ ???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-11-2015, 05:52 PM
Jesse's Avatar
Jesse Jesse is offline
Connector $35
Pin $35
Those TNC connectors are crazy expensive. I hope you can find a way to get just the parts. If so, please post to the list.
Jesse Saint
Old 05-11-2015, 06:41 PM
Mike, I talked to Stein before I posted this. He used to stock the pins, but no longer. I'll call Walt tomorrow. I will post a link if I can find a source--surely I'm not the only one that ever messed up a pin.
Steve Riffe
RV-8
N23SR
Old 05-11-2015, 07:37 PM
Walt's Avatar
Walt Walt is offline
I can save you the call, I have the connectors but no extra pins.
Mouser has them for $18
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-11-2015, 07:47 PM
Charles in SC Charles in SC is offline
It has been a while since I made mine up but are the pins different between the right angle and straight ones? If they are the same it would be cheaper to buy a straight one to get the pin.
RV 7
Old 05-12-2015, 10:02 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default a work-around
1. TNC-BNC adapter.
2. BNC 90 degree adapter.
3. BNC male crimp plug for your RG-400.
Some connector loss, but dirt cheap/plentiful online.
-Stormy
Old 05-12-2015, 09:11 PM
Thanks for the replys. Mouser no longer sells the pins by themselves. I may check Digikey tomorrow- if no joy, I'll bite the bullet and buy another complete package. Moral of this story--ya only get one chance with these TNC connectors, so get it right the first time!
Steve Riffe
RV-8
N23SR
