Old 05-10-2015, 03:01 AM
karlb123 karlb123 is offline
Default Converting fixed prop to CSU VP airplane
Hi Guys,
New member here so please go easy on me. In the UK and looking at the RV market and have eyes set on a RV6-A. My friend 4 years ago purchased a completed RV8 but despite my role in airworthiness for an airline and his RV8 ownership neither of us know the answer to the following question...
If this RV6-A is fitted with a 2 blade metal fixed pitch proper and a 160Hp LYCOMING O-320-H2AD...would it be mechanically possible to upgrade this to a CSU/VP prop system?
Thanks Guys
Old 05-10-2015, 03:22 AM
az_gila's Avatar
az_gila az_gila is offline
It's almost certain it will be a FP version only.
However, an MT electric prop should be able to do the job...
Buy one now while the Pound is high...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-10-2015, 03:24 AM
Thanks for your reply,
How do you know it would almost be a FP version only- does the engine type and following letters in LYCOMING O-320-H2AD indicate that? Sorry I am just trying to understand the basis of this :-)
Thanks again will look at MT electric system
Old 05-10-2015, 11:00 AM
az_gila's Avatar
Exclamation
It's the uniqueness of the Series 76 engine that was made to be a "cheapie" for Cessna 172's.
My info comes from the latest Lycoming Illustrated Parts list for the "H" Series 76 O-320 models.
It does not have the usual accessory case that would house the prop governor and has none of the usual attachment locations due to the integrated single piece crankcase/accessory case casting. The -H models are quite unique in their construction, which is why they need a special engine mount from Vans.
Gil Alexander
Old 05-10-2015, 01:04 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Also, the H2AD has a solid crank and that would not work with a hydraulically controlled prop.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
