Do you really need an audio panel?
If you have just a single nav/com, can you wire the nav and com outputs together and feed that into the intercom, using the volume controls to select which (or both) you want to listen to? Yes it's clunky, but will it work?
thanks
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
