  #11
Old 05-09-2015, 07:00 AM
Robert Anglin Robert Anglin is offline
Originally Posted by guidoism View Post
I know what my mission profile is right now but I'm not quite sure what it will be in 5+ years when I finished with the plane.
I'm still years away from needing to make a decision on anything firewall forward, but what I'd like to do at this point in the build is become educated about engines and their options. As a renter I never really got to know much about the engine underneath the cowling. I want to understand.
I want to read. But my googling and amazoning hasn't turned up an obvious place to start.
How did y'all learn about these engines?
Should I start with the powerplant book in an A&P course or is there something more specific for Lycomings that would be a better start for me?
You are as I see it correct, get the tail kit, be putting it together and doing all the study and home-work you can while you are building. Don't take much at face value till you have investigated it and it has ben tested and proven to be correct by more than two independent reputable sources. Just like Walts post. Ask do roller lifters help a low R.P.M. air cooled engine or do they help a water cooled Hi-R.P.M. engine? Do roller lifters help with an engines wear or dose regular starting and running of an engine with either type of lifter wear just the same as the other? Is spalling of a mushroom lifter do to its old stile desinge or lack of regular lubing and running of the power plant that they are installed in? And on and on. One of the things that I enjoy about Aveology is there are so many things to and questions to be asked that it is hard to get them all addressed in one life time. You have the will, you have the questions, you took the step in the right direction. That is clear from your first post. Welcome to the real world of frustration of ones self into getting the answers you want. It is worth it, for as you will hear often the principle tenants of our little hobby are education and recreation. Keep it up you are doing good. Yours as always. R.E.A. III #80888
Old 05-09-2015, 07:02 AM
BillL BillL is offline
Originally Posted by Walt View Post
Just curious, what lab did that data come from and was this some kind of "predicition"?
Real world numbers have not proven that to be the case to my knowledge, and I've never heard an engine builder (the guys who see this stuff everyday) make any such statement.
Email sent, Walt. It was bench, engine and analyses for various combinations of materials etc. Extreme conditions of used oil, limit temperatures and speeds. It was on diesel engines with an expectation of 8000 hours life. Analysis showed that very high contact stresses. ZDP was very important, so for Lycs, additives are quite important. Chilled iron followers are the most difficult to obtain consistency. Maybe with follower replacement at 2000 hrs, the results would be much different for a long test.
The results were so contrasting, I have chosen rollers ever since.
Bill
RV-7
Lord Kelvin:
Old 05-09-2015, 09:24 AM
brad walton brad walton is offline
My understanding fom reading the Superior Engines website info is that they were able to incorporate a steeper cam profile with roller cam followers than with old style. Thus the valve remains fully open for a longer time period. If I recall correctly, all the Lycomings now come with roller cam followers.
Old 05-09-2015, 09:47 AM
wirejock's Avatar
wirejock wirejock is offline
Default Induction
Can someone please expand on the horizontal vs vertical induction pros and cons?
Edit
I found an excellent write up.
See post #6
http://www.vansairforce.com/communit...read.php?t=298
So now my question is what comes standard on the Vans Lyc M1B?
I would like Aerosport FI, P-mags and auto plug bosses don't believe there are options so the engine would have to be modified and no doubt the warranty would be invalidated.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-09-2015, 12:01 PM
rzbill's Avatar
rzbill rzbill is offline
Larry,
The Lycoming stock experimental classified YIO-360-M1B has a horizontal forward facing sump and Precision RSA-5 style fuel injection servo. It comes with roller tappets, slick mags and is set up for constant speed prop including the SS line from the pump pad to the crankcase nose.
this means you need the smooth bottom cowl and you do not need a fuel return line.
Bill Pendergrass
ME/AE '82
Old 05-09-2015, 12:40 PM
wirejock's Avatar
Originally Posted by rzbill View Post
Larry,
Thanks Bill.
How difficult is the swap to auto plugs? Inserts from Emag or can the plug bosses be removed and changed?
Larry Larson
Estes Park, CO
Disclaimer
Old 05-09-2015, 01:39 PM
jrs14855 jrs14855 is offline
Default Information
Start with a Lycoming Operators manual for one of the more popular engines. Then Lycoming Overhaul Manual. The next step would be the Lycoming Engine School, but that is beyond what most builders would need, unless you wish to assemble and engine on your own.
Old 05-10-2015, 04:14 AM
rwtalbot rwtalbot is offline
Default Genuine
Pretty hard to beat Van's show special for a Hartzell and Lycoming IO-360-M1B. Roller cams and injection would definitely be on my list if I bought new. Mags can be sold later and PMAGs added.
It just doesn't seem right to me that non-genuine is more. That was not the case when Mattituck, ASP and others got going assembling kit engines....
Another issue is if your engine will be built from all PMA'ed parts. This gives you some protection as any AD's would be issued for the certified fleet. Newer experimental engines are not being made with all PMA'ed parts, and to some extent it is unknown how they will perform and there may be no vibration testing with your chosen propeller.
ECI Titan cylinders are more resistant to corrosion. That's probably a good thing for anyone who doesn't fly regularly. Pitting in the cylinder bores is at least as big an issue as cam failure. ECI cylinders are prompted by engine shops for this feature. The ECI cylinders also come pre balanced to 1 gram and ready to install on the engine. Perhaps this might have something to do with the engine shop's interest in using them as well.
I haven't had great luck with my ECI cylinders. I replaced a set at 350 hrs due to an ECI AD. To be fair ECI looked after me well, despite the fact that the engine shop I bought from walked away. I was really happy with the replacement cylinders ECI provided.
From observation the ECI cylinders run hotter and take a lot more to run in. They tend to be less repairable that their Lycoming counterparts due to the harder bores.
For what it is worth, I just bought 6 new Lycoming cylinders for my next project. I bought plenty of other parts from ECI and Superior as well. In future I plan to build my engines locally from good cores, as opposed to buying new from Vans or an engine shop.
Richard Talbot
RV-7A
Sydney, Australia
Old 05-10-2015, 08:59 AM
pvalovich pvalovich is offline
Default Engine Choices
First determine your mission / requirements. After that chaos will start to seem logical.
My RV-8A requirements: cross country, some acro, mostly solo (wife refuses to get in the plane - but that's another story), reasonable speed, reasonable weight, reasonable operating expense, proven reliability to compensate for my admitted lack of engine expertise. Sufficient excess power to handle Sierra Nevada mountain flying out of homebase of Inyokern, CA, on eastern side of Sierra.
Decision: Aerosport IO-360 180 HP Horizantal Induction with one mag and a Lightspeed EI. Hartzell CS prop. B&C 40 amp alternator with SD-8 backup.
Aerosport was great to work with; felt the additional performance of 200 HP wasn't worth the cost, weight or operating expense.
425+ hrs in four years. No problems, no regrets. It's a magic carpet.
Old 05-11-2015, 02:17 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default TCDS
Type Certificate Data Sheets for the certified Lycoming are available on the FAA's website. This should provide a start on letter designations/differences. Don't know if these letter designations carry over to the kitbuilt engines. Anyone?
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
