Just make sure you have disconnect fittings and flexible lines with enough slack to pull the panel out. I just mounted mine near an inspection plate, and it is just as easy to access, however.
I did mount my OAT sensor on an inspection plate, and on hindsight I should have just placed it nearby, eliminating one connector from the system.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
