Old 04-17-2005, 04:59 PM
szicree szicree is offline
Question RV4 canopy skirt seal
What, if anything, do people use as a seal where the rear portion of the canopy skirt meets the aft fuse skin?
Steve Zicree
Old 04-17-2005, 08:53 PM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default rear canopy skin
Steve...
I didn't use anything. The skin rests on the turtledeck which has only a thin layer of clear scuff tape for protection.....no problems so far with this arrangement, and it looks neat and clean too.
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Old 04-17-2005, 09:40 PM
Question follow up on skirt question
Thanks. So here's my follow up question: How much pressure should the skirt exert on the turtle deck? Is contact all that is needed?
Steve
Old 04-24-2005, 09:38 PM
Default skirt pressure
Steve,
When I move the canopy lever forward to lock.....it pulls down on the canopy ever so slightly (this happens because the holes in the blocks are drilled on a little bit of an angle) so that there is a little pressure on the skirt.
Marc DeGirolamo
VAF # 144
