Sounds like carb
When is the last time the fuel servo (not carb) was rebuilt?
I recently worked on a Glastar that sat for a couple years with little running. The airplane and engine look new and another mechanic purged the system and cleaned the filters in preparation for it to fly. However...
On the takeoff role, the engine lost power and just quit. Started back up and seemed to run fine but, like you, wanted a deeper look into the cause.
Pulled the servo and spider, sent them off for inspection and they found them so clogged with deposits that he said it would be more cost effective to replace them both - which is what we did.
All good now after an hour test flight above the airport.
EDIT: Could also be vapor locking.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Reason: edit for IO vs O engine
