Old 05-07-2015, 09:15 AM
pierre smith's Avatar
Default Front seal question
How can a front seal be pushed out of a 4 cylinder Lycoming if the breather tube is not plugged, nor fitted to the exhaust with that controversial orifice?
It happened a couple of days ago near here.....details later.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-07-2015, 09:58 AM
Mel's Avatar
Mel Mel is offline
Running a F/P prop without the rear plug pearced/removed will cause this.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-07-2015, 10:15 AM
Ralph Inkster Ralph Inkster is offline
or insufficient or wrong adhesive applied or applied to dirty surface
or retainer ring not installed (some applications)
or wrong seal (split / not split)
or incorrect 'clocking' split seal on installation
or stuck relief valve
or ...
Could the thermister or filter bypass cause a surge?
I also seem to remember oversized seals being available for overbore cases.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
